Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
iPhone 3GS won't charge after battery replacement
Hi,
I bought new battery for my 3GS. Using the iFixit guide I replace it. But i think that I broke something while unscrewing. Now my 3GS won't charge. I attached photo with marked broked "thing". How to fix it?
http://imageshack.us/f/263/p1010596f.jpg...
Score -1
Add a comment
1 Answer
Chosen Solution
Hello,
Possible solutions:
1) Insure that you replaced the battery with the correct one for your phone. The 3G/3GS ones look similar, but have vastly different internal structures. Insure the battery you replaced yours with has a model number the same, or the last digit is the only one that is off.
2) While I suspect that the part broken may have part to do with the charging issue, I'd recheck all the connections, focusing on the dock one.
3) If that does not work, I'd try replacing the dock for a new one.
4) If none of these worked, your board is likely shot. You can try soldering that spot or bringing it to someone that can. However, I do not know of a repair guide for this problem.
Hope this helps,
Xico Solutions
Add a comment
Add your answer
Kacper Sztechman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 950
