Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Questions View all
Is this mark in the corner fatal?
Hi there - I have this small mark in the corner of my phone. it has been there for a while and everything still works, however I am trying to sell it and want to inform the
buyer if it is likely to stop working because of this mark. Is it a water mark?
Add a comment
It looks more like a pressure mark to me. I don't think it will stop working, more of an aesthetic issue.
Add a comment
Looks like it’s cosmetic to me and shouldn’t cause an issue. It should be fixable with a screen replacement.
Add a comment
So the glass is epoxy bonded to the digitizer and the LCD display. Because of this, there can be no water penetration to give a watermark like that on a laptop screen. Now that that’s out of the way, the discolouration is a matter of pressure.
As most of the contributors has suggested, this is pressure against the LCD from the back (inside) the phone. If you review the iFixit teardown, the top left of the battery is behind that screen (marked in green). This could be a sign of the battery swelling which will cause the battery to not function in the long term and the “bubbling” or swelling will continue across the entire battery.
(iFixit image)
The iPhone 7 series are sealed phones with an IP rating of 67, which means they are water resistant up to 1m. *IF* you able to, I recommend you get the battery replaced at an apple store with an authentic battery because Apple will seal the unit correctly. This way, any issues, the next person can take it back to Apple.
If you take it to a third party, they can replace it and may do a great job but since you are selling it, if the new buyer has an issue with the battery or takes it into an Apple store, they will be refused service.
I recommend you inform the buyer about the POTENTIAL issue (or repair yourself) as I am doing a BEST GUESS based on the evidence seen. There could have been a drop or something else causing that pressure internally.
This is not a cosmetic issue as it shouldn’t be under any pressure behind the screen. Treat this as an undiagnosed issue that may grow into something bigger IMO.
Add a comment
Add your answer
francesca woolley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 32
