Display starts bright and then becomes dark. Inverter?
Hello,
when I turn on my MacBook the internal Display is working normally. After some minutes the display gets darker and darker until you nearly can't see anything anymore. Using the Macbook's keys to make it darker and then brighter again will help for some seconds. When I turn off the display for some seconds by using the active corners it gets completly bright again and within seconds it starts to get dark again.
So what can I do? The late 2008 Unibody Macbook has allready LED backlight. Is there an inverter at all? What can I check? And how can I find out which typ of an inverterboard is used so I can order a new one?
Thanks for any help or suggestions!
