Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
Why isn't my touchscreen responding after digitizer repair.
LS,
My iPhone 3G stopped responding to my touch. Looking on this website i figured i had to install a new digitizer. So i replaced it using the front panel kit.
After i fixed this problem it still doesn't work. I think this problem could be a software problem, but i wouldn't know how to fix it.
Do you have any ideas?
Thanks in advance.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
What makes you think the fault is software related?
Did you notice the issue after an update / jailbreak attempt?
Firstly, try resetting / restoring to see if that works.
If not, then I would say disassemble and check your connections, especially cable 2 at the top end of the phone.
Did you definitely buy the right version of touch and fully secured it?
Sounds stupid but you wouldnt believe how many I repair with the wrong touchscreens on or the cable only half way home.
Hope I helped.
Score 2
Comments:
+absolutely agree!
by
Well, i think it's a software problem because with my old digitizer it worked after it was 'broken' for a while.
I already tried the restoring/resetting, but it doesn't work as well.
I also bought the right hardware to fix my iPhone with, so that couldn't be the problem as well.
The only thing i could do is check the connections, but i don't know if that's going to help.
Thanks for the questions!
by
Add a comment
Add your answer
lesterverhoef1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,085
