Battery icon displayed when connected to charger only, then shuts down
Got a used 15” Macbook Pro 2015 DG. Plugged it into a third-party charger, fans spin up and screen displays a battery icon with a little bit of red and a lightning symbol below it. No light on the magsafe connector. Shuts off after a few seconds. Same behavior when I power it on with just battery with the addition of a plug icon. I disconnected the battery and tried powering on with just the charger, but no change. Also tried resetting SMC.
Eventually I replaced the magsafe board and also moved all components (except battery and touchpad) to a new upper case. Magsafe connector now lights up, initially green and then stays on orange, but still shows battery icon and won’t boot. I have a genuine charger on the way for further testing. I’ve not found any information describing the exact same symptoms I’m seeing.
Be weary of third party chargers as they can damage Apple devices. Danj would be a better resource for answering this but from what I'm guessing is that the battery is in a deep discharge state and needs a little bit of time to charge up (if it even holds a charge). The third party charger may not be providing adequate amperage (power) so maybe give it an hour or so before trying to boot up.
by DunCanP
@dunc Thanks for the feedback! Would the laptop boot up and work normally if it was running off of a genuine 85w charger without the battery connected? And would the magsafe connector have a constant green or orange light?
by Simon S
@dunc - Review these!
● Don't Replace Your MacBook Charger With a Cheap Knockoff
● OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
● Lacking safety features, cheap MacBook chargers create big sparks
● FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
ONLY USE A REAL APPLE UNIT! And only directly from Apple Apple 85W MagSafe 2 Power Adapter (for MacBook Pro with Retina display)
by Dan
@danj , not sure why I should review 3rd party adapters since I don't use them, condone the use of them or buy them... LOL. I use only genuine apple adapters after watch Jessa Jones showing how iPhones die with non-apple charging cables or chargers.
In fact, my first statement made it clear. I think you meant to post that to the OP @amujee
by DunCanP
@amujee Your MBP should work with a geniune apple charger with no battery connected. Since there is no battery to charge, it would stay "green" but may momentarily change to "amber/orange" at initial connection.
by DunCanP
Show 2 more comments
