Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1954 Questions View all
Why is my iPhone has a voice describing the thing I click?
My iphone has been describing the things i click (using voice) and i had to click it once then double click it to go in to the apps or typing words
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Sounds like your voice-over is on. Try this to turn it off"
VoiceOver
If VoiceOver is on and you want to turn it off from the device instead of from iTunes, remember that a double-tap acts like a single tap and you need to use three fingers to scroll when VoiceOver is on:
1. Press Home.
2. Tap Settings. Then double-tap Settings.
3. Tap General. Then double-tap General.
4. Use three fingers on the screen to scroll to Accessibility.
5. Tap Accessibility. Then double-tap Accessibility.
6. Tap VoiceOver. Then double-tap VoiceOver.
7. Tap "On" next to VoiceOver. Then double-tap "On" to turn it off.
You can configure the device to display options for VoiceOver, Zoom, or White on Black when you triple-click the Home button. This feature is off by default; to enable it, tap Settings > General > Accessibility > Triple-click Home."http://support.apple.com/kb/HT3577
Good Luck
Score 1
Comments:
ill try later , thanks!
by
It worked! Thanks!
by
Thank you for accepting my answer. Best of luck to you and your phone :-)
by
Thank you for this. I was scared because of this triple click home button. And i couldn`t do a restore because i have i cloud activated. !@#$%^& !@#$ voice command
by
Add a comment
Add your answer
Jit Han will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 32
All Time: 1,663
