Screen on boot up scrolling. Then going white
When I boot up the screen is scrolling up reall fast and then it starts fading to white. What is causing this please I can’t use my MacBook now.
@markstill45 - You'll need to plug in an external monitor to be sure. If the external screen is showing this as well then your logic board (CPU) will need to be replaced. If not then its the internal display (T-CON)
Ok mate tx.
I’ll have to work out how to do that, and which cable to get.
Depending on what you find with your test will aim us to which part to replace the logic board or the display.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 34
Can you post a short vid so we can see what you are seeing Adding images to an existing question
by Dan
Done that Dan. Also tried pram reset. Took back off to check ribbon connection to screen all looks ok.
by markstill45
