Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
Why theres no small black latch on cable 3?
i opened my iphone, and theres no small black latch that holds the cable 3, i dnt know what to do, i cant removed the cable 3, pls help..
Add a comment
1 Answer
Chosen Solution
If connector 3 is white the latch is black. If the connector is black the latch is white. The small latch just flips up with gentle push up. Then cable 3 slides smoothly out.
Score 2
Brad is spot on, the only other choice is that the phone has been opened before and there is no tab. Try just gently sliding the cable from the connector.. it isn't like cable no.1 or 2 that pop up, this one slides in under the white or black cover.
Add a comment
Add your answer
lex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 537
