Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
171 Questions View all
What is the USB port power output?
How many watts do the usb-c ports output?
Score 1
Add a comment
1 Answer
Chosen Solution
Apples spec page for the MacBook Air (M1, 2020) Systems specs Which does not list the USB-C USB4 output power!
Sadly the standards are not cut and dry as it depends on what the two devices agree to per the Release 2.0 - USB Type-C Cable and August 2019 Connector Specification:
Three current level advertisements at 5V VBUS are defined by USB Type-C Current:
• Default is the as-configured for high-power operation current value as defined by a USB Specification (500 mA for USB 2.0 ports; 900 mA or 1,500 mA for USB 3.2 ports operating in single-lane or dual-lane, respectively)
• USB Type-C Current @ 1.5 A
• USB Type-C Current @ 3.0 A
There is a clear functional distinction between advertising Default versus the USB Type-C Current at either 1.5 A or 3.0 A.
• Default is intended for host operation in providing bus power to a connected device where the host manages the device’s current consumption for the low-power, high- power and suspend states as defined in the USB base specifications.
• USB Type-C Current at either 1.5 A or 3.0 A is primarily intended for charging applications. The Sink can vary its current draw up to the advertised limit. Offering USB Type-C Current at either 1.5 A or 3.0 A is allowed for a host providing bus power to a device. The host needs to assume that the device will continuously draw up to the offered limit.
Here’s a bit more on USB-C & USB4
Score 1
1 Comment:
This first article you linked says a minimum of 7.5 Watts for USB 4, so that seems good.
by
Add a comment
Add your answer
William Davis will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 81
All Time: 8,099
