Android OS / 4GB Capacity which can be upgraded to up to 32GB / Model A270a / Black and White
80 Questions View all
My phone went into the water
It went into water then i took it out then when i press the power button it turns on and then immediately turns off itself by itself without me wanting it to turn off it basically i turn it on and it turns off by itself
Add a comment
Chosen Solution
Hi
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there and corrosion is occurring there also. The ends of any flex cables and their connectors need to be cleaned as well.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit BLU Advance 4.0 repair guides for your phone which may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 1
Add a comment
Hello Kiduse, If your iPhone fell in water then there can be a few things that can make it turn off like water damage. If water gets inside the phone and touches any component then it might fail, witch explains why it shuts off when you try to power it on. Have you tried to inspect the internals of the iPhone?
Add a comment
Add your answer
Kiduse Yohannes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 30
