AirPort and Bluetooth not available after repair
Because my clutch cover was seriously cracked, I decided to replace it, using the guide on this website. All went well -I thought- but when I restarted the macbook, AirPort and Bluetooth are not available.
What I did:
- checked all the connectors twice
- PRAM reset
- SMC reset
- Restoring the permissions on the hardddrive
Now I'm lost. Did my macbook just die on me or is there just a simple solution? Help is very much appreciated!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Have you checked the connectors on the airport/bluetooth card? On this model it sits in the display frame, under the clutch cover. Chances are that something is amiss there.
Score 2
Comments:
I tried that, but visually nothing seems to be wrong. Strang thing is that the fan keeps spinning at max speed. When I close the lid the macbook shuts of, in stead of going to sleep.Any thoughts on troubleshooting this?
by
Add a comment
first try to remove the camera cable from the log board then check your laptop working normal or not . if the laptop behaving normal then the problem is in the cable or you have done something wrong . then try to remove the cable from the bluetooth board and clean all the jacks and reconnect them all . this may solve your problem
Score 1
Add a comment
Add your answer
Edwin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,080
