Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3232 Questions View all
Is the battery compatible with both 220 V and 110 V?
iv ordered a battery for my new iphone 4 which i got from canada ( was brought to me by some one ) and when i got it it had a problem where it rebooted randomly and every few min while charging
after searching around the net i understand it might be a battery problem
the phone was charged only via voltage converter ...
( but dunno if whoever brought it to me did the same )
so my question is does it matter if i plug it into the wall charger without the converter ? ( is the battery affected by 220 V /100V )
thanks .
Add a comment
Free Shipping on all orders $79.00 and up.
Browse Our Store
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
1 Answer
Chosen Solution
The battery should not be affected by that. Ultimately your phone will still receive the same voltage. In this case it is regulated by the different AC adapters. It does not matter if it is 220-5V or 110-5volt. your error does sound like a battery problem. I would try to replace the one you got, and/or try to recharge with a local AC adapter without the need for a voltage converter.
Score 1
Add a comment
Add your answer
mahmoudhanadi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,143
