Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
565 Questions View all
PC3-8500 RAM instead of PC2-6400?
I'm wondering if I can use the 2x2GB PC3-8500 RAM modules I've got left after upgrading a new Mac Mini (2011) in a 20" iMac (iMac8,1, early 2008), which is spec'd to use PC2-6400 modules. Is the 8500 just capable of higher bus speeds, or are they really incompatible?
Add a comment
1 Answer
Chosen Solution
Won't work--the Mac Mini ram is 204 pin and the iMac ram is 200 pin. They are physically incompatible. Your best bet would be to either to sell the PC3-8500 modules and but the correct ones or to find someone to trade ram with you. Good luck.
Score 4
Comments:
Thank you! And right, I should have read the Wikipedia entry properly — I saw both (DDR2 and DDR3) mentioned 240 pins, but it's actually SO-DIMMs. Plus there's also "DDR3 DIMMs have 240 pins and are electrically incompatible with DDR2."
So I guess I should have done my "homework" first — sorry... :)
by
Add a comment
Add your answer
Andi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 1,965
