Should I replaced the Left I/O Board for power issue?
I have a MacBook Pro 15" Core 2 Duo Model A1211 that was dropped. It runs just fine off of a charged battery, but it does not power on without a charged battery installed (does not work off charger alone) and it does not charge the battery when it is plugged in.
Would the root of this problem lie in issues with the Left I/O board? Can you recommend any testing to isolate the source of the problem?
Thanks!
2 Comments
Was the charger connected when it fell? What color do you get on the magnetic power in tip? How are you charging the battery now?
by mayer
The port appears fine. The USB and audio out on that side work. Usually removing the battery is okay if the power supply is plugged in. I tried a different charger, but had the same results.
by Ivan
