Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
What is my iPhone screen unresponsive?
I have a iPhone 6 plus, and I had the common problem that there would be vertical lines coming from the top of the phone and it would be unresponsive. I figured I could fix it, so I bought a new screen and display. I put it all back together and the lines have gone away, but the screen is still unresponsive. Can someone please help me?
Add a comment
1 Answer
Chosen Solution
If you have replaced the screen and checked the touch connector is seated properly than it will be the common problem on the 6 plus known as touch disease. Usually to permanently fix this issue a micro jumper wire is soldered under the touch IC (meson)
As the 6 plus is getting on you might be able to put some packing on top of Meson although this will not be a permanent fix it might work until you can upgrade. To permanently fix this problem you would be looking at around $90
Score 1
2 Comments:
Thank you for your speedy answer. Is there any way that I could get it fixed for a lot cheaper? Also, I don't know many of the things you said. Is there a guide online as to how I could do it myself?
by
Add a comment
Add your answer
Benji Ash will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 42
