Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1401 Questions View all
Where is the cmos battery?
I have a liquid damaged 2007 macbook 2.1 GHZ (A1181) that's working fine but isn't charging the battery.
I swapped out the DC in board and battery connector with known working parts but the issue remains.
I tried an SMC reset several times but to no avail.
I decided to disassemble it to clean up the logic board (there was some corrosion on some areas) but when I took it out and turned it round to remove the cmos battery there wasn't one. I assumed it was removed and not replaced as the macbook had clearly been opened before, but I couldn't find the jack for it.
Here's the type of logic board:
This is the one I've seen before, where the cmos battery is placed in the middle of the board:
Where is the cmos battery to be connected on this logic board?
Add a comment
1 Answer
Chosen Solution
It sounds like you have the Santa Rosa or Penryn version of the MacBook which has a slightly different location than earlier models. Here is the guide showing the location.
Score 1
Thanks Matt! Not calling it the "PRAM Battery" was obviously the downfall of my fruitless searching.
Add a comment
Add your answer
Eoin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 44
All Time: 9,016
