LG TrommWM2487HWM will not drain after changing pump and control board
I got OE code. I changed the drain assembly (including both drain & circulation pumps). I removed and cleaned the tub to pump and pump to drain hoses, there were no clogs. Still would not drain. I had pumps checked at local electric motor shop, they are good.
I changed the control board and the machine still will not drain. It passes test 11 & 12 of the QC Test Mode. It seems to fail test 2 & 3 - the machine does tumble. Everything works fine until it is time to drain. What else could it be?
