Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Why won't my phone turn on after battery replacement
I replaced my battery in my iphone 6 followed ll the directions off here and it worked perfectly fine before but now it won’t turn on
3 Comments
Check that the battery connector is seated properly.
by
it is still no budge
by
If you still have your old battery try that, if it doesn't work there could be a damaged component on the board or the screen itself coulve broke
by
Add a comment
Most Helpful Answer
Does the phone turn on with the original battery? If so, it could be a problem with your replacement battery.
Score 1
Add a comment
Check the connections on all the connectors you touched, clean them.
Add a comment
Add your answer
Adriana Cassano will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
