Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
do all older iPhones screw up on ios 4?
I got this phone from a friend that quit turning on. I brought it home conntected to itunes nothing , then a flash white screen. I took it apart and saw that it seemed like the battery had maybe leaked. So I soaked and scrubbed it dried it ,viola it worked. Except the phone would shut off after about 5 minutes and i noticed the battery percent would react weird during boot. I've read about the os 4 messing up the battery and the speaker is low which i've read too. Are all versions of ios 4 going to have a problem on the older iphones or am I gonna try to have to downgrade back to 3 to see if this is the problem I like the ios 4 but if it won't work causing it's pushing it too hard then no choice.
Comments:
did you replace the battery? or did you just clean it up? if you didn't swap it I'd do it now..your problems sound battery related. People wouldn't leave a leaking battery in their car..same principle here.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
There is a small amount of phones that have had problems..I think the majority have updated firmware and never have a problem. All of my phones have been updated, no problems.. I thought my wifi had been affected but a simple open and stick it back on again worked. If you don't want to update then don't but the only way to downgrade is to jailbreak or use tinyumbrella if you've saved your shsh blobs..Jailbreaking has it's own little pitfalls, and as you are on ios 4.x you may find that the only one available to you is the ipad jailbreak which may wreck gps/wifi anyway!
Sometimes I think that people find coincidence and link it to problems, bit like someone who tries lobster mornay for the first time and gets food poisoning, the fact that it was the pate earlier in the day doesn't seem to register..
Dropping phones breaks speakers, the 3GS is 2 years old-the battery is at the end of it's life and is bound to start failing. Maybe the update uses more energy for some processes and this hastens the battery death? Once a battery starts failing they go very rapidly downhill. People link these things and blame ios updates.
If you are truly worried sit back, leave the phone as is and wait until everyone else has tried it and reported any problems. imho no problems so far..
Score 2
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 309
