Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
274 Questions View all
Turn off by it self,and won't turn on.
When use the mac for half a hour,it will turn off by itself, and should waiting for one hour or more,can turn it on.
Comments:
At first ,i thought it will be overheating,after i checked everything,no overheating.and today i checked the power supply, that has problem.thank you everybody.
by
Add a comment
Chosen Solution
Sounds like something is overheating and shutting you down. Take the cover off and observe the diagnostic LEDs to the right of the RAM slots (this may be covered by a piece of black electrical tape). Jason may be right about the power supply, if so none or just the first LED will remain on after it shuts down.
Score 2
Add a comment
Most Helpful Answer
It's hard to say based on the info you have provided, but I think you need to replace the Power Supply. You should do all of the normal tests such as resetting the SMC/SMU, reset the PRAM, and remove and reseat/replace the RAM. HTH. :)`
Score 2
Add a comment
Add your answer
tomma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 722
