MacBook Pro logic board
I spilled water on a macbookpro 13 and i need a new logic board but dont know what one i need the serial number is w89355mx66d
Before buying a replacement logic board you may consider sending your logic board for repair. I sent many "spilled logic boards'' to an electronic shop in Ontario Canada and most of the times they were able to salvage the board. You'll pay about $200 for the repair and nothing if it can't be repaired. Check for these shops on ebay...
Your replacement logic board options are the 2.26GHz Apple part# 661-5230 and the 2.53GHz Apple part # 661-5231
Here is the specs for your machine per the serial number:
http://support.apple.com/kb/SP541
Based on the serial number this should be the machine you have:
http://www.everymac.com/systems/apple/ma...
Ifixit and eBay have logic boards for this model. (ebay sellers in most cases are helpful in insuring you are ordering or bidding on the correct item if you go that route, just make sure shipping insurance is included )..... you could also order the 2.53Ghz version if a 2.26 is not available.
You might want to check the input for power to make sure that isn't the problem before replacing the logic board, i doubt it but worth checking. Here is the device page for you model:
Just fyi, I found a deal on ebay for the logic board, if that helps, I recently just replaced mine so yeah:/ But definitely do your research and all, make sure with the seller that it is the actual parts.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,216
