Problems with screen after long time not using
Had it lying around for about 1~2 years. After charging up and open back the screen turns into some water-ish damage almost entire screen while the edges still looked normal.
Is the screen panel damaged? Or is it some steam trapped between screen panel and glass panel?
1 Comment
You'll need to plug in an external monitor to be sure you don't have anything deeper.
If you are able to get it going enough I would also check your battery as it likely needs replacing, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by Dan
