My psp doesn't charge
The psp doesn't charge when i plug the charger in
Ali, if you checked the battery and all the connectors as well as contacts as Phillip Takahashi suggested and it still does not solve your issue, you might want to take a look at the logic board fuse. Great information on the fuses etc is available here and of course here with the instructions. Give this a try before you buy a new logic board.....;-) Should you be really bored and you like to learn more about this, you can download the BOARD SERVICE MANUAL 1st edition Level 3 from here :-)... good luck
is this a psp 2000 or 3000 board?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,427
1 Comment
Have you tried a new battery yet? If the battery isnt the problem the next step is to open the case and make sure that all connectors are in place. If they are, unfortunately you may need a new logic board.
by Phillip Takahashi
