Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Questions View all
Why doesn't work the backlight of my iPod?
Hi everyone!
This is a big problem for me because I love this iPod. The ,,back” button (left button) under the clickwheel was broken. I have a donor motherboard so I just replaced the broken button. I tested the iPod after the button replacement work and everything was fine then I put the motherboard in my ultrasonic cleaner because I used flux. After the ultrasonic cleaning the backlight didn’t work. I tried with an another display but the situation is same.
I need a schematic to the repair or any advice that where can I find the backlight circuit.
Please don’t write that: ,,Just buy an another motherboard”. This isn’t worth It and I just want to repair this iPod.
Thanks in advance to the replies.
Add a comment
1 Answer
Chosen Solution
@karl67 schematics for the iPod are not available. Since you have a donor board you would have to go and measure the components and see if you find the one that has shorted out. I would focus on the coil around the display connector. If you have a meter you can check pin 30 which should be Backlight -Neg and pin 31 +Pos there will be a boost circuit to get the backlight voltage (again check for shortened out coil)
2 Comments:
Thank you for the answer! I will check the pin 30.
by
The problem was with the backlight IC. I reballed and the backlight works fine.
by
Add a comment
Add your answer
Norbert Jauch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 52
