1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Questions View all
Replace the paste on the GPU on the iMac Intel 17"
Which one of the two heat sinks has the GPU underneath it?
Should I reapply the thermal compound on both heat sinks while I'm at it?
Score 1
Add a comment
1 Answer
Chosen Solution
I would use the CPU fan replacement guide to point to which one is for the CPU. That guide is here. Personally if you are having heat issues I would reapply thermal compound/paste to both the GPU & CPU. You do not apply thermal compound/paste to the heat sink, it is applied to the processor - thin as possible, yet still covering. A rough guide for applying thermal compound is here. I recommend using the Arctic silver thermal compound/paste available here.
Electronics Skills Image
Guide
How to Apply Thermal Paste
Difficulty:
Moderate
5 - 20 minutes
iMac Intel 17" CPU Fan Image
Guide
iMac Intel 17" CPU Fan Replacement
Difficulty:
Difficult
Score 3
Add a comment
Add your answer
Shay Aviv will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,857
