Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
211 Questions View all
If I install an ssd via m.2 area, will the temp sensor still go buggy
So I have a late 2012 21.5 inch iMac, I got it for free from my school, I’m wondering as they removed the HDD, if I only install an M.2 drive, will the temperature control sensor go off as it does if I don’t use this adapter thing. Or will the iMac ignore that it doesn’t have a normal drive? Sata…
Basically, can I leave the SATA and power cable out on the iMac and only have an M.2 drive.
Asking so I know before I dump 200 into a 2tb M.2 drive
2 Comments:
I would strongly recommend you review this guide The Ultimate Guide to Apple’s Proprietary SSDs Apple does not use M.2 SSD's
by
Hi, I understand, I have this adapter thing that my friend gave me from is 2012 macbook
by
Add a comment
1 Answer
Your M.2 drive should work just fine. If you use a PCIe slot that’ll save you the hassle and is much faster than the SATA port.
Add a comment
Add your answer
David bellows will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 61
