Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
Toching device, Right side = malfunction.
Recently replaced my front glass. However i cannot type "p", seems like right of the screen does not work.
Also noticed that the original glass had a marker (black tape) back of the LCD. just right where the touch doesn't work.
Do I have to do the same on the new one ?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The tape won't effect the overall functionality of the digitiser, it is probably there as an identifier for the supplier or other identifying purposes. There are three things that could of happened.
One - You have not connected the Digitiser correctly to the logic board
Two - You could have damaged the digitiser ribbon upon installation
Three - The Digitiser you have purchased is faulty
One -Unscrew the EMI plate that covers the LCD/Digitiser connections at the top (shown below) and make sure all of the connections have been made and are secure.
Two - Now to make sure that your digitiser has not been damaged you are going to need to disassemble the iPhone and take the screen off. Take a look at these connections here to see if any damage has occurred.
Three - If all of the above options have passed and nothing appears to be wrong visually, then the digitiser might just be faulty and you will require a replacement. Contact your supplier to organise a replacement. Its always good to take a photo/video of the issue as proof of the fault.
Hope this helps :D
Score 5
Comments:
Thank you very much! Will try this once I get home.
by
+ very complete answer...
by
Add a comment
Add your answer
Hoang Vu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,938
