Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
soldering, locations, why?, iPhone internal
what parts in a iphone 3gs are soldered?
Add a comment
1 Answer
Chosen Solution
If you are referring to parts you can replace/repair...only the mic/speaker on the dock assembly. It is possible to buy that unit all in one though so technically you don't need any soldering at all. Unless of course you are more interested in parts on the motherboard? in which case after you have removed the emi shield..everything including NAND etc is soldered.
Take a look at a guide for removing the to the right under the photo of the phone. You'll see the only tools required are a philips head screwdriver, spudger, suction cup. NO soldering iron.
The iphone 2g had a battery that required soldering to the logicboard, as do several ipod's.
Score 2
Add a comment
Add your answer
Aryan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 428
