Released November 2018 as an edition to the iPad's Pro line. Model A1980.
61 Questions View all
Touch does not work after screen broken glass replacement
The screen glass broken the glass part was replaced. If you check the attached picture, you can see that there is a whole vertical bar where the touch does not work. I used note app to make it clearer.
Hard reseting does not seem to solve the problem. Could it be a hardware problem? If yes, do I need to replace the whole screen or are there ways to fix just the damage part without replacing the whole screen?
<screenshot of the note app reveals areas where touch does not work at all>
Add a comment
1 Answer
You’ll need to try a new screen. If that doesn’t fix it you may have caused damage during the repair process.
Add a comment
Add your answer
Adnan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 129
