Advice for cleaning motherboard from water damage?
I’ve opened it up and definitely see some corrosion (also it doesn’t turn on).
I got this advice from a Apple discussion board post (https://discussions.apple.com/thread/250...):
“Put a little bit of Isopropyl Alcohol onto the corrosion and let it sit a minute or two before using the toothbrush to very gently brush it clean. Do not press on the toothbrush or you will likely break the very small and delicate surface mount components from the board.
Blow some compressed air across the area to push out any alcohol which may be trapped beneath the components. Let the board sit an hour to let any remaining alcohol evaporate.
Make sure to disconnect the battery from the Logic Board before performing this procedure.”
Anything to add? Also, should I take out the board and clean both sides of it?
1 Comment
Arg, I need a T3 driver!!
by Igor Dikiy
