My ps4 wont turn on anymore and beeps 3 times when I turn it on
i put my ps4 on rest mode last night before going to sleep this morning i tried to turn it on and watch a movie but instead it just beeped 3 times slowly when i pressed the power button on the console it is a PS4 slim model CUH-2215A
Score
0
any light indicator along with the three beeps? sounds like a hard drive fault. you can try to boot into safe mode by holding the power button down until it chimes for the second time. see if it will boot to the safe mode screen with an error.
by jostewcrew
@jostewcrew at the time it lasted for about a week there was no light indication and i switched cables put it in a completely different outlet and it turned on for a sec i was on again for about 5 minuites then it said the ps4 was overheated and shut off again after that i touched the ps4 and it did not seem to be hot at all so i switched all my cables again and went to a new outlet and set up a dan pointed at the ps4 and let it sit there for over 24 hours and eventually it started to work after that just like new i have no idea what went wrong but i am extremely grateful that it started to work again
by DANK GIRAFFE
@DANK GIRAFFE ... then it sounds like an overheating issue. i would open it up, clean the fan and its housing and replace the thermal compound. heres a guide:
PlayStation 4 Slim Fan System Replacement
by jostewcrew
