2.26 or 2.4 GHz / White plastic unibody enclosure
618 Questions View all
water spillt! Starting problems. What should I do.
hello,
My macbook got water on it. I tried starting it once it was dry. It starts ans cut's off after 1 minute.
So I took it apart, but it seems like the motherboard never got water on it. All components seem clean and dry. I only had a issue with the keyboard staying blocked.
Once I put it all back together, I still had the same problem. Starting fine after 1 minute turning off.
I have a reset the SMC and PRAM. I have also done a apple hardware test. No results.
One more information, by deconnecting the track pad, the mac does not turn off.
What should I check, test? What is the next step?
thank you
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Sounds like you need to replace the trackpad. Links provided.
http://www.ifixit.com/Mac-Parts/MacBook-...
MacBook Unibody Model A1342 Trackpad Replacement
Score 3
Add a comment
That test was done. I have tried deconnecting the trackpad and cable and plugging a new one. No difference. Still the same problem. thank you for your answer.
Add a comment
Add your answer
max will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 698
