CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
418 Questions View all
iPhone will sync, not charge.
I plugged my iphone in last night, and it's been having some problems lately saying "this accessory is not optimized for this device." Well over night, it decided to not charge. It shows the plug thing on the battery, but it's discharging, and flickering on and off the accessory warning. IT WILL SYNC! but it won't charge. :(
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Clean you iPhone Dock port with a clean dry toothbrush. Try to charge again. If still problem, all Verizon iPhones still have Warranty Coverage, take iPhone to Apple for resolution of this problem.
If you want you could, use the toothbrush with a bit of Isopropyll Alcohol and clean again, especially the pins which are on top of the mid rib. Let it dry for a minute. Try to charge again.
Score 2
Add a comment
Add your answer
Eric Shaver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,389
