Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
19998 Questions View all
Spilled coffee on it. still works but doesn't charge.
spilled coffee on my mac and its still works i turn it off by it self turn i upside in 2sec drained it all out took the back off barred it in rice and but near a window for 3 days. cleaned the rice out turn on fine but wont charge anymore.....is it the battier or something else
??? im just tired of always plugin it in
Score -1
1 Comment
The only way I know to check if its the battery is to check battery voltage. If the battery voltage is far below that of its rated nominal voltage, the battery is toast. Don't macs also have an indicator of battery health? Does it indicate any problems?
by
Add a comment
1 Answer
Chosen Solution
Could also be the charging circuit
at the magsafe, OR at the battery terminal. Look for burns on the logic board using a strong magnifier, look for corrosion on the contacts. If you see corrosion you could try a non-conductive contact cleaner.
You could try taking the battery to a battery/electronics store and see if they can charge it or check it.
Good Luck.
Score 2
1 Comment:
Check to see if you have charging voltage at the battery terminals. +
Electronics Water Damage
by
Add a comment
Add your answer
Bryce Froats will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 785
