Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
12977 Questions View all
Spilled coffee on it. still works but doesn't charge.
spilled coffee on my mac and its still works i turn it off by it self turn i upside in 2sec drained it all out took the back off barred it in rice and but near a window for 3 days. cleaned the rice out turn on fine but wont charge anymore.....is it the battier or something else
??? im just tired of always plugin it in
Comments:
The only way I know to check if its the battery is to check battery voltage. If the battery voltage is far below that of its rated nominal voltage, the battery is toast. Don't macs also have an indicator of battery health? Does it indicate any problems?
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Could also be the charging circuit
at the magsafe, OR at the battery terminal. Look for burns on the logic board using a strong magnifier, look for corrosion on the contacts. If you see corrosion you could try a non-conductive contact cleaner.
You could try taking the battery to a battery/electronics store and see if they can charge it or check it.
Good Luck.
Score 2
Comments:
Check to see if you have charging voltage at the battery terminals. +
Electronics Water Damage
by
Add a comment
Add your answer
Bryce Froats will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 765
