Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Touch does not work
Hello. my Problem is Iphone 3GS touch does not work , I change touch, but does not work. help?
Score -1
Add a comment
1 Answer
Chosen Solution
First step is Reset, hold both Home and Power buttons until the iPhone begins to restart itself. Usually less than 20 seconds.
If still problem. Possibly Flex Cable #2 (Digitizer Flex) has come loose from the Logic Board.
If still problem. You may need to replace the Front Glass, it normally has the Digitizer attached at the Factory. So this would be Front Glass with Digitizer replacement for 3GS it is one part.
Before opening iPhone 3GS and during any repair make sure the iPhone is OFF or you risk damaging the LCD Display or Display Logic Board Controllers.
Add a comment
Add your answer
zafar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 170
