Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Probably a cable break of the display?
As soon I open my display more the 90 degrees, I got a black screen. Not totally black because I can still see the content very darkly.
When I move the display to 45 degrees and back to 90 degrees it is ok again.
Anyway 90 degrees is very uncomfortable.
Is it perhaps a cable break of the power cable to the display? ...or what can it be?
How exactly can I repair it and where do a find a manual for it?
Score 1
Add a comment
1 Answer
Chosen Solution
Your inverter cable is broken internally. You need to replace it. Instructions for replacement are in this guide. There are 2 different inverter cables for the A1181 MacBook one is referred to as 4 walls the other as 3 walls. Here is a video that does a good job of explaining the difference between the 3 walls & 4 walls. I would use part of the fore mentioned guide to remove the upper case/keyboard to get a visual as to which cable is used in your MacBook. I would buy a new one if possible. If you buy a used one, buy from a reputable seller that puts a warranty on the part. Here is a google search to help you find your part.
Score 3
1 Comment:
you‘re just great... thanks so much :-)
by
Add a comment
Add your answer
myblogtrainer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 324
