Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
TsOP Sensor Failed, CPU Fan Running Full Tilt, and Super Slow
I had a run in with a water spill a little while back on the trackpad of this Early 2011 13” MacBook Pro. I immediately took it apart and let it dry out for a few days before reassembling. Ever since, the CPU fans run full tilt, and the computer is unusably slow. I’ve had some success in safe mode with a more responsive system, but it’s still running hard.
AHT has identified the TsOP error (shown below):
I’ve since run iStats and found another potential set of angry sensors.
I’ve replaced the trackpad cable to no avail so far. I think the trackpad itself may be shot as well. I’m debating whether it’s worth it to get one if this thing’s likely dead anyway. I’ve tried disconnecting the iSight camera, wireless card, and trackpad. No combination of those disconnections resulted in positive gains.
Any thoughts/ideas?
Update 07/18/20: So I pulled it open to trace the lines, and I frankly am not certain where to begin. Am I going to need to pull out the logic board and trace on the backside? Wanted to confirm that it's needed before going down that rabbit hole again.
Add a comment
1 Answer
The only thing I can think of is the cable connector or board connectors are damaged so the signal is not getting through to SMC.
How about tracing out the line from the track pad logic board to the main logic board.
4 Comments:
Thanks @danj for the quick response. Time to but out the trusty multimeter... I'll let you know what I find.
by
Whats up , any news on the error?
2025
by
@leandroath21196 - did you trace out the line as suggested to Nick?
by
@danj yes it is like new nothing out of ordinary
My issue aggravated even more after I ran apple diagnostics which now led me to reinstall ventura again since It froze OS,
Sad lol
Keep it up
by
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 107
