No green light after disassembling liquid damaged MacBook Air
I have a liquid damaged Macbook Air and bought a Nice wire Magsafe 2 45W charger which gave me a green light. After the disassembly, I have no green light. I have not damaged anything during this. Is it possible that this has happened because it is not a genuine charger? Apple do make ways of finding if the charger is not genuine to reject any input so that you can buy there chargers for extra cash.
I do feel that it might be the charger as I have no diode readings no that there is no green light. The adapter sense/one wire circuit is used as a way to reject non genuine chargers but I want confirmation and other possibilities.
8.1V on PPBUS_G3H and other 8.6V Power rails? Liquid damage.
I have a liquid damaged Macbook Air. Readings are 8.12V on 8.6V power lines and 3.38V on PP3V42_G3H yet no green light.
PP5V_S5 is not present. S5_PWR_EN has no voltage and so, SMC_PM_G2_EN has no signal to. Is this a bad SMC? It has the 3.38V from PP3V42_G3H. Thanks.
Thanks.
where did you buy the charger from? Where was the liquid damage located?
by Jesse Hooton
@hootonberg It was from Amazon. I have even used a genuine and still the same. Damage around SMC, some near TPS51980. S5_PWR_EN has no voltage and SMC_PM_G2_EN has no voltage. SMC receives 3.38V from PP3V42_G3H. All 8.6V always on power rails are 8.12V. Is it an issue with the SMC as it is not outputting SMC_PM_G2_EN?
by Moh
What is the impact of this? It was a Nice wire charger with a good Amazon rating. What is the damage? Could it not be that the flex cable may be damaged?
by Moh
Amazon and eBay don't sell REAL units! These are knockoffs!
Review the Blue links below. The way these work damages the charging logic. Between damaging the DC-In Board, MOSFET's, sense logic and the SMC chip. I've seen it all and then some!
No such thing as a Nice charger! The ratings are bogus!
by Dan
@danj So what should I repair, how would I know what is causing 8.1V?
by Moh
Show 9 more comments
