Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
218 Questions View all
Is it possible to repair middle button operation?
The middle button of the click whee is not responding. Is it possible to repair it without replacing the entire front plate?
Add a comment
1 Answer
Chosen Solution
You will have to disassemble it. Check the micro switch on the logic board right under the middle button. Make sure it has a click feel to it. If it seems to feel like the other ones, I would start by replacing the click wheel. Also make sure the middle button makes good contact with the switch. this guide shows you how to remove the logic board. the click wheel is right under it....Good Luck
Score 1
Comments:
Thanks very much. I'll give it a try.
by
you are welcome and let us know how it is going. If you need more help, just ask..;-)
by
Add a comment
Add your answer
rjantoniono will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 708
