1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
257 Questions View all
Dead iMac, Black Screen, No Chime, No nothing.
I am working on an Intel iMac (Early 2006?). I assume this because of what I've been told, also, its white, and has no LEDs-- Its dead as a door nail. I've hooked it up to other monitors, I've tried booting it in Target Disk Mode to another computer. I've switched out power cords, tried different outlets and pulled the RAM out trying multiple scenarios. As far as I can tell the next step is to crack it open. Should I be targeting the PSU (Power Supply)? Not sure how to test these, could also be Video Card or Motherboard I'm told, maybe with a dead computer though it can be anything.
Comments:
Please look on the bottom of the stand and give us the last three figures of your serial number
by
serial number: W86459NJVUX
by
I should mention that rumor on the street is this happened after a big thunderstorm over the weekend.
by
Apple iMac "Core 2 Duo" 2.0 17-Inch Specs
Identifiers: Late 2006 - MA590LL - iMac5,1 - A1208 - 2114
by
Add a comment
Chosen Solution
Try unplugging everything and pressing the power button for five seconds then attach the power and keyboard and see if you get anything on startup.
Score 7
Comments:
just tried that, got nothing.
by
I don't hold much hope for a cheap easy fix. There may be diagnostic lights to the right of the RAM slots. Open it up and try to start and see if you get any lights. You should get #1 green even if the power supply is gone.
by
I don't mind the cheap pain in the butt fix, its the expensive pain in the butt fix I'd like to avoid. When you say to the right of RAM slots-- Is that looking at it straight on as if I was using it normally, or looking at the bottom of the iMac straight on to the RAM slots? I can't seem to find them, they should be labeled 1,2,3 & 4 correct?
by
Some of these early ones didn't have the leds. Most that I've seen are covered up by a small piece of black tape extending up from the bottom of the logic board to the right of the RAM slots as when normally operating it. Take it off.
by
http://imageshack.us/photo/my-images/534... here's a pic, still can't find it, or the black tape.
by
Show 10 more comments
Add a comment
PSU look no further, maybe it can be repaired, anyway easy to change if its only that
Add a comment
Add your answer
Flynn Stewart will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 17
All Time: 5,830
