Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Cannot hear ringer, keyboard clicks, etc, but I hear music from iPod
Suddenly my ringer doesn't work. I switched ringtones, I reset my phone from itunes to its original state. My mute button is switched to the correct position and from the settings, sounds, ringer is turned up all the way. All sounds are turned to the on position. I hear no ringer sound when I'm being called and no keyboard clicks, alerts, etc. I DO hear music from my ipod though. Don't know what to do and I am missing important phone calls. PLEASE HELP!
I have purchased several parts but have not installed any yet in the hopes that I've missed something. Do you know if the ringer speaker with antenna cover needs soldering?
Score 1
Add a comment
1 Answer
Chosen Solution
if the ipod works in headphone mode then it makes sense..but if the speaker works for music then it's a bit of a puzzle. Do your headphones work? have you tried cleaning the headphone jack of dirt and dust just to make sure they aren't tricking the phone to "headphone mode". I think this is probably the headphone/volume flex but it all depends on whether your speaker works at all. The speaker is housed inside the dock connector and it's connection is soldered to the USB/microphone flex (connector no.4) It's a PITA to try and remove the speaker and solder/desolder for the sake of a $1..just buy the dock with all parts attached.
so no.1...do your earphones work?does music play on loud speaker?
2. clean out the headphone jack with a cotton tip, try rapidly putting jack in and out (20 times)
3.replace the headphone jack
if you have no sound from loudspeaker with music then I'd replace the dock
Score 3
2 Comments:
Thanks friend, but my speaker works because I can hear the music both with headphones and out loud without them. I had bought the mute switch and switched it out myself and after that I hear the keyboard clicks 20% of the time....but now my camera will not work. HELP!
by
either open the phone again and check that the connection is on properly or if that doesn't work then you'll need to buy a new one..they're pretty cheap.
by
Add a comment
Add your answer
Fotini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,126
