Changed battery and now driver's side window won't go down and door lo
Door locks and window on driver's side don't work after I cleaned my battery post
I doubt it had anything to do with you changing the battery. You need to check the fuses. There is a fuse box under the hood and one inside the car. If those are good I would check and verify that you have no power to the switches. If not and the fuses or breakers are ok I would verify that you have power before the the door. You wire loom on the door hinge can be pinched and break a wire. You will have to test these with a volt meter or test light. And it doesn't matter how the white looks like on the outside it can be broken inside.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 249
