Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1501 Questions View all
Why wont my iPhone charge or be recognised anymore?
hi there after using my iphone for 2 years it all of a sudden started flickering so i went to check the connections on it. after making sure they were fine i reassembled it and it worked brilliant for a few weeks. then it started flickeringagain so i decided to strip it again to make sure the connections were fine, which they were.
however after i reassembled it this time there was a very high frequency buzzing coming from the dock area of the iphone and the apple logo appeared which then fades away. it doesnt seem to charge by any means and it will not be recognised by itunes. every time i put the charger into it i hear a very high pitched buzzing, the apple logo appears, then after 5 seconds the buzzing stops and the logo just fades out to a black screen.
i would appreciate it if somebody could point out whats wrong as i dont want to have to buy every single part of the iphone to try and rectify it.
i have already boughta new dock/charging connector and replaced it but still nothing.
thanks in advance to anyone who can help!
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Answer
Chosen Solution
You may have accidentally knocked one of the small noise reducers off near the dock connector..they're about 1-2mm long. You may not have connected your dock connector (no 4 properly) so that charge isn't getting to the battery, or your battery may have been the cause of the problem to start with if it is 2 years old. I'd replace the battery, recheck and reposition your connectors (again) and see what happens. If it is the noise reducer then search users for james bond..he had this happen and posted his repair on here.
Score 1
Comments:
hi pollytintop, many thanks for your swift help, i dont think its the battery as it held its charge well, i will however try the other suggestions you gave me. i will be back in touch, once again many thanks for your help. regards darren
by
Add a comment
Add your answer
darren macdonald will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 799
