Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
How to replace my Rear panel?
Hi everybody,
So I have some probleme with button on my iphone (random vibrate due to silence button damaged and power button not working anymore)
I friend just gave me the rear panel from his old iPhone.
I just have a question, at what must I pay attention to prevent any damage to my iPhone?
I readed the guide too
Does someone damaged his iPhone by doing this?
Thanks
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
if you are careful and considerate then it shouldn't be a problem. If something doesn't fit, don't force it, make sure you can see what it is you are pushing/pulling/installing. Look at the way your motherboard is shaped and where camera/sim tray/headphone jack/dock are.. this will guide you in putting the motherboard in safely. The motherboard needs to be inserted sim tray end first and sits under a little lip near the power button, if it isn't in right there then your sim tray won't go in, and your LCD won't close..just a hint. ***Make sure before you do anything that you work on the phone when it is turned off (or run out of charge)
Score 2
Comments:
Thanks, I will take care of all you said to me !
by
Add a comment
Add your answer
Saxch will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 202
