Repair guides for the MacBook.
3786 Questions View all
My Mackbook Core 2 Duo 2007 Black can-not charge the Battery.
This Macbook is working all fine just that it can't charge the battery.
- The battery is good as I charge it externally with the External Charger I bought - meaning I can use my macbook for like 2 hours or so at one charge.
- Following the ifixit and some other forums I have now replaced the faulty part which is Meg Safe Dc - in but still it doesn't Charge.
I appreciate you guys reading this forum , please Suggest me something if you have in Mind.
Thank you, Joy.
Add a comment
1 Answer
Chosen Solution
Check the battery connection for corrosion and completeness. Also check its connection to the board. If all that is good and you have a meter see if you are getting charging voltage to the pins.
MacBook Core 2 Duo Battery Connector Replacement
Score 2
Add a comment
Add your answer
joykubavatz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 359
