Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
226 Questions View all
Display compatibility between iMac
I just got an iMac 21.5" A1418 - Late 2013 (EMC 2638) with a broken screen/LCD and i have laying around a iMac 21.5" A1418 - Late 2012 (EMC 2544) with a good screen and a bad motherboard. And I was planning to use the screen, would anyone know if the displays are compatible?
tl:dr is the EMC 2544 display, compatible on a EMC 2638?
Thanks!
Add a comment
1 Answer
Chosen Solution
TheBookYard lists them as compatible to each other! 21.5” iMac LCD Panel & Front Glass Assembly (12/13), Apple P/N’s 661-7109, 661-7513, LG panel ID #’s LM215WF3 (SD)(D1), LM215WF3 (SD)(D3)
Score 1
Comments:
i'll give it a try and let you know, thanks!
by
Installed display and everything boots ok, image and everything Thanks!
by
Add a comment
Add your answer
Robert G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 111
