What a component is missing on the logic board iPod Touch 1st?
On the logic board damaged one component. I suppose it was resistor. What is it and what is its value?
Thanks
Thanks
According to my multimeter the (missing red circled) component in the middle is most likely a resistor of 0 Ohms. The components in direct neighbarship left/right are 3.8kOhms resistors. The use of 0 Ohms resistors is not unusual in smd designs - often used as bridge or fuse (which might also explain why this component is gone).
Hello Chris. Thank you for your answer. In my device without this element resistance between two points of soldering is 0.0 ohms. It's strange, but looks like that this element is not needed.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 662
