Timer advances past drain cycle without draining
Hi, I have a Kenmore 110.92580100 that doesn’t enter the drain or spin cycle. The timer continues to advance past that cycle until it hits the post-refill agitation cycle, then it shuts down at the normal time (with the dirty water still inside).
To be clear, the timer keeps moving until the end of the entire wash cycle, but the drain/rinse cycle is not activated (there is also no spinning).
Maybe a bad door switch or timer relay?
Hi @jonnycat ,
Can you manually drain the water from the washer by setting the timer on the drain or spin cycle, you didn't say?
if not I'm wondering if it may be the drain pump part #22 Brake, clutch and gearcase, motor and pump assembly.
by jayeff
