Fix Your Stuff
Right to Repair
Store
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3306 Questions View all
Question Closed
Earpiece sound distorted and too loud after screen replacement
My earpiece during calls is too loud even at the lowest volume setting. It's so loud that it even distorts the sound of the other party speaking.
I replaced my iPhone 4 display twice and disassembled it several times more to fix stuff I have overlooked due to my lack of experience.
Now, that earpiece problem appeared after the second display replacement.
I changed several firmware versions inbetween the assemble/disassemble games so I'm not excluding a software issue as well, but I was wondering if there's a possible hardware reason for that - something I messed up when I was assembling it back.
Thanks for your input.
Add a comment
Are all connectors attached properly? The connector(s) may disconnect when re-assebling. The connector(s) might also be dirty.
Comments:
Could it be the connectors to blame? I mean... it's not that I'm losing some of the sound, it's just too loud causing the earpiece to crackle right form the FIRST volume bar.
by
Perhaps I hevn;t lodged the earpiece correctly, I just found this on the Apple forums:
"I took mine to a genius bar and they replaced the handset as they said the earpiece was evidently defective and loose in its housing causing distortions."
by
Perhaps it is the connectors. check the connector again to see if the problem is still precent.
by
Add a comment
hi.. i have the same problem.. i have awful sound with my earphone after replacement my screen.. bass sounds are disorted.. did you fix yours? i will be happy if you share your solve..
thanx..
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,835
